Data entry on totals for column algorithm
Question asked by emanuela.dolce on Feb 27, 2018
Latest reply on Mar 5, 2018 by sebastiangurt
Hi, I have a dataview with two infocubes and a column algorithm c=a/b with summary algorithm calculated. On the row axis there are aggregated entity and the data entry is enabled. It is possible to write on the deepest entity. It is also possible to write on totals for the columns a and b (infocubes),
but I can't write on totals for the algorithm c.
I would have the possibility to write also on the total calculated of the column c and use the reverse algorithm formula to re-calculate each row. Does anyone have any tricks to have this behavior? Thanks!
