Dates shown in Browse and used in WHERE are offset by 1
Question asked by bbroughton on Jul 31, 2018
Latest reply on Jul 31, 2018 by bbroughton
Just wondering if anyone in the community has come across this issue before and found a robust/correct way of dealing with it.  BROWSE doesn't match what is loaded into a CUBE.
The Browse on a SQL query shown below lists several dates by employee.
The Dataview below shows what is actually loaded into the relevant date cubes, with the Commencement date also loaded into a text cube for comparison
The dates don't match!
What is showing in the BROWSE (and also used in the SQL where statement) are offset by 1 day. So someone that has a Commencement on 1 July will actually be mapped against June, because it sees their commencement date as 30/6.
Also, today is 31/7/18, yet when I use sysdate() or curdate() (Progress DB) they both return 30/7/18.
I can quite easily reverse the -1 day offset in the WHERE statement by adding a day, but I would rather work out why the SQL is seeing/using a different date to what is actually there, in case it's something temporary and a fix like that will cause issue down the track.
Does anyone have any ideas what would be causing this?
