NEXEL: Dynamic calculations on WEB not working
Question asked by Paul Wyatt - Avison Young UK on Aug 3, 2018
Latest reply on Aug 4, 2018 by Paul Wyatt - Avison Young UK
Is anyone aware of issues when using NEXEL on the WEB?  I've created a process that uses a dataview incorporating a nexel calculation.  The screen works perfectly on 10.1.4 Desktop but fails when used on Web.
The action of the routine requires the user to select a SOURCE property.  Values are selected from the SOURCE and written to helper cubes.  The helper cubes are used in a dataview which takes the values and performs, using NEXEL, a calculation for each of the other properties.
As I said, this process works perfectly in DESKTOP, saving the SOURCE property, calculating and writing the values for all other properties and displaying the results in a chart.  However, within the web environment, the SOURCE property is saved and displayed, but the calculations, created by NEXEL, fail to write to the cube used to display the results in a chart.  The final result is that source properties accumulate each time the process is run and only the data from the DESKTOP session is ever displayed in the chart.  I've tried clearing the helper cubes at runtime too but to no avail.
Any advice would be appreciated.
