I've stumbled in a report requirement that requires using a column offset in a rule. I've defined it and applied in the dataview, but it have no effects on an entity that I've applied the rule. Details in the screenshot.
Any help would be appreciated. Thanks in advance.
the offset is regarding the Block and not the by Row entity.
So if you have to Blocks (A and B) and Block B has a Rule with Column offset, it is refering to Block A.
So in your case just add a 2nd Block with and offset (so Block B will use the Rule, Block a is the same Block without Rule but with a time offset)
Björn
