Dataview display issues
Question asked by bencampbell on Oct 22, 2018
Latest reply on Oct 25, 2018 by bencampbell
I have a screen that fails to display any data when first opened. The first cube is the most complex and under details it says "unable to analyze this block". If I change this to another cube, press OK, then change it back to the original cube, the data displays correctly. So Board does not like the initial layout, but once it has loaded the layout successfully I can switch to the desired cube.
Has anyone come across this before? I have used screen triggers to change when the layout is loaded but it seems it will only work once one of the blocks has changed (and then changed back). Have also tried using a simplified version of the troublesome cube but the same issue occurs.
Any suggestions on how to solve this?
Thanks.
