Hi Team,
It would be really great if the Data entry lock can be enabled for the Group Total or Grant Total cell. And the Split and Splat should work on the the group level first and then to the individual cells.
Currently even if you lock 1 total on the lowest group total, then the entire group/Grant total is disabled.
In the below screenshot, the Red highlighted Totals dont work. Only Green Highlighted works.
