Level 200: Module 212 - Not seeing any data after running Procedure
Options
Update, I was able to see data after running the procedure for Italy; The issue is with UK data. Had similar issues with UK data in a previous module. I am ok with the result of seeing only Italy data for the purpose of this training.
Emmanuel
Hi Emmanuel,
Thanks for raising this. Please could you share a screenshot of your 'load' data procedure, and specifically the step that is running the data reader. I suspect that your data reader is only running 'Italy' files instead of 'All' files.
Many thanks,
Snehal
Hi Snehal,
These are the 2 load data procedures that I have and they are both set to All
Emmanuel
