Level 300, Module 305: Functional Test - Question 1 - numbers don't match solution
Numbers are negative what they should be - e.g. Classic for CY is -132956 and should be 132956, Double Halo for CY is -407938 and should be 407938 etc
Hi @longdnbs
Can you please help us with a screenshot of the Sales Planning screen from your Level 300 training environment? We need to check other values appearing in the adjacent block.
Hi Marcus - thanks for the quick response - see screenshots attached β¦
Could you please double-click on the CY values for all 3 entity members, one by one. This will redirect you to Sales plannign adjustment screen. Can you share a screenshot for all 3 just like below?
Classic
Double Halo
Grey Pearl Stud
Updated file attached - many thanksβ¦
I can see that all the values for these new products in the sales planning adjustment screen appear as negative numbers instead of positive numbers. I suspect you've misconfigured procedures (of this module 305) associated with the cube PLN - DF - Sales LC.
I would recommend going through each step from the place where you created these new products. Search (Ctrl+F) - Add New Products for Driver-Based Planning in the module 305, and check all steps after that.
If you find all steps were followed correctly, I recommend deleting these 3 products (Entity members) from the Datamodel > Product Entity. (Note: I've recreated this step when I faced a data mismatch issue and it worked for me)
Let me know if it works!
One more workaround that was helpful. Try this if it works for you.
After this, check all the default screen selections are as below
Then, follow the on-screen instructions from module 305 > Functional test.
Let me know if it works.
Thanks Marcus, will take a look and let you know.
Hi Marcus, I have checked what you suggested - deleted and recreated the three products and worked through the rest of the exercise and still get the same result where the numbers are negative. I checked through in detail the procedure to make sure I had set it up correctly and as far as I can see, I have. I don't fully understand at a cube by cube and dataflow level what is being done in this procedure. Let me know if you need any more information. Thanks in advance.
Hey, did you get a responses on this or did you just use the figures from the screen shots above? I've got the same issue and have gone through the steps and coming out with the "wrong" figures.
