I want to ask about how to rename or alias header title column Dataview? Because I have no found of solutions about it inside official documentation.
Thank you previously.
Hi @Ilham Maulana Habibie ,
ok—that you can do to some extent. So long you don't flatten any hierarchy (or only have one entity) in the rows, you can set the title of the "by-row entity".
Consider this example where the title is exactly the same, left without flattening the hierarchy, right with:
That title can be set in the layout editor
As soon as you flatten a hierarchy with more than one entity displayed, the system will use the entities' name for display.
Best, Helmut
well, currently you are displaying the name of the cubes you have put in the columns. That's the standard.
You can change the title of each column in the according section of the layout editor:
Hi @Helmut Heimann,
I mean for customizing title Heading for entity, not for cubes or algorithm. Is there any way to customize title Heading for entity only without dragging entity into data block?
