Hello Community
In the current Entity Analysis / Impact Analysis view, temporary cubes are not included — which limits our ability to fully understand how an entity is used across the application.
⚠️ If an entity is used in a temporary cube, and that temporary cube is used inside a procedure, the link between the entity and the procedure will not appear in the impact analysis.
This leads to incomplete or incorrect results in the impact analysis and creates a risk when recycling entities.
Suggestion:
Allow temporary cubes to appear in the Entity Analysis / Impact Analysis
Adding this feature would improve:
- Procedure maintenance efficiency
- Debugging and impact prediction
Akrem
