Dear
While building the Indirect Global expense account, the dataview is not in dataentry mode despite dataentry has been set on the cube.
Any help would be appreciated.
Khaleelah
Hi @Khaleelah ,
can you please check that by selecting the "Version Status" you have selected a version implicitly?
If that's not the case, the hierarchy should be repaired.
You can check that a drill-down by Version should show only one row.
Best, Helmut
sorry, I've seen on the screenshot you've provided that only one version is selected (FCST3+9).
You could next check the database security → Cube visibility settings which should look like this
And then, of course, the months' settings in the cube "SET - DF - Actual Months" and the Planning lock in "PLN - DF - Lock Planning".
