is it possible to load an unbalanced entity throught smart import ? Because i can't find de parent code in the mapping part
Hi Tommy, As far as I remember, you can't find the parent entity in the displayed list of entities. However, I believe there are some workarounds. One of them is to use a cube to store the link with the parent, and then perform an extract-reload operation to make the link effective. But I suggest to avoid this kind of gymanstics as much as possible :)
Hi Fethi
Thanks for your advice , i afraid that's too complicated for the operation š„
@Tommy0411 that's the origin of my suggestion. Make it simple as much as possible :)
Could you clarify the part about the cube? Iām not familiar with that technique.
