are there any plans to work on the loading speed of a flex grid?
When i load the same data into a dataview it works fairly quick however when i do the same in flex grid it takes minimum 2 minutes + to load.
Br, Maik
Dear Maik,
Thank you for sharing your question with us.
Actually, you are comparing two different objects, which - back-end speaking - work differently, since they are designed for two different kinds of analysis. More details can be found here. Hence, it can be expected that the execution time required is different.
That said, we can surely investigate your case; hence, I recommend opening a ticket to the Support Team, so that we can assist you on this.
Greetings,
Martina
