Unable to enter data in Indirect Global Expense Planning template.
Cube used in the template I enabled the Data Entry. Can please help me in this
Hi @Gaurav Singh
Thank you for your post related to Level 300, Module 306 Functional question 2 problem.
I would like to inform you that you have also created case 00168719 for the same issue, and we have already provided the resolution steps there.
For your reference, please check the following:
2. Review the Database Security → Cube Visibility settings:
3. Check the month settings in the cube “SET - DF - Actual Months” and the planning lock in “PLN - DF - Lock Planning”:
If the above checks do not resolve the issue, kindly provide the following details so we can investigate further:
We’ll continue supporting you under case 00168719, so please use that ticket to share any updates or additional information.
Kind regards,Nigel Adams Board Product Support
