@Yogeshwar
Thanks so much for sharing the screenshots. They are super helpful and give me a much better picture of what's going on. 👍
From what I can see in your "Expense Actuals" report, the good news is that your variance and variance % calculations appear to be working perfectly based on the CY and PY numbers shown. That means the setup of your final report screen is likely correct!
This usually means the difference in values is happening before the data even gets to this report. Let's dig a bit deeper into the data-loading and conversion process.
To help me pinpoint the exact issue, could you please share a few more screenshots?
Once I can see those three things, I'm confident we can figure out what’s causing the different results. We're almost there!
Now, i just did the same 209 again i am gettinh the values right, but please check if there is any errors
Of course!
Great news! I've reviewed all your new screenshots, and your setup for Module 209 now looks perfectly correct.
Your FX rates are right, the raw data is loading correctly, and the final report values are accurate. There are no visible errors.
Well done on fixing it!
