Hello all,
I hope you are doing well.
I am reaching out because I am stuck on my Level 200 module.
While following the instructions, on Section 8 part H, I am asked to build Data Reader to load Member and Relationships.
I managed to connect to the .csv file, but when I try to set up the mapping, I just can't seem to do it correctly.
When I try to map the fields, I can't choose the correct column :
Either I select the whole "Product Code ,Product Desc., Product Group, Product Category", or "Column1" - no inbetweens. I can't just select "Product Code" - when I write it down myself and type enter, it automatically selects the one above.
I thought that maybe this might be a bug ? Might also just be a bug in my brain.. haha, but I really can't figure this out.
Can somebody please help me out ?
Kind regards
