We are experiencing an issue with the Disable Drill Down setting in Cartesian Charts where it is not saving when you tick the checkbox.
When the changes are saved and then the browser is refreshed, it resets the setting and still allows you to drill down.
Is this a bug and is there any workaround?
Thanks!
