Hi everyone, I'm trying to recreate the Flex Grid layout shown in the screenshot (I've hidden the cube names, hopefully that's not an issue).
In Cube 3 (Block C), I enabled Data Entry and set Detail By = Column: Month. Data entry is locked by Condition Block G, which is an algorithm also configured by Month. Due to the validation conflicts I encountered, I had to set Detail By = Month for all cubes to resolve those issues.
The only remaining problem is with Entities. They are not configured by Month, and if I try to set them by Month, I get another validation error saying that **Entities cannot be entered by Month**.
I'd also like to mention that I implemented the exact same layout in a Data View on Board 12, and it works without any issues. The problem only occurs with the Flex Grid on Board 15.
Has anyone faced this issue before, or does anyone know of a workaround or the correct approach?
Thank you in advance!
