I have this situation:
- one dataview having a few blocks.
- one block of this dataview:
- uses the "detail by" (layout > block > detail by > select one entity for the detail by) function.
- has data-entry enabled
- uses the "suggested values" function using an entity and its members
This works. The dataview is shown, i can enter and save data, everything fine.
Now i want to apply also the Cells Locked by Block function for this block.
I am not sure if this is supposed to work or not.
I select the cube used for data-entry locking and then the dataview does not render anymore. It displays: "cannot run the requested analysis".
The layout "issues" section shows "no issues" so i cannot know whether i am doing something allowed or not:
I found nothing in these sections regarding limitation of the combination "detail by", "dataentry" and "cells locked by block":
- "Detail by" feature of a layout's block: https://help.board.com/docs/detail-by-or-by-column-block-settings
- lock data-entry based on cube : https://help.board.com/docs/data-entry-block-settings#cells-locked-by-block
I would expect any limitation to be specified in one of these two sections
Has anyone already met this issue? How do you combine the two features "detail by", "cells locked by block"?
Board version 15.1.0.1.616479
