Anyone having same error. I have checked my built a couple of times but didn't found any clue
Hello @Inayat Ullah,
Thank you for sharing the details and the screenshot.
The error message “The data you uploaded does not match the data validation rules. For cell H ‘Value’” usually means that the data in the uploaded file does not match the mapping or validation rules configured in the Data Reader.
Could you please compare the Map – Configured columns to Data model destinations and the Define rules for the external data settings shown in the course material with the mapping configured in your environment? In particular, please check that the destination field for the Value column and its validation rules match exactly as shown in the course image.
If the mapping looks correct on your side, please share a screenshot of your mapping page. This will help us validate the configuration and identify what may be causing the validation error.
Thank you, Jeff Williams
this is the mapping, thanks for looking into the matter!
Thank you for sharing the mapping configuration.
We reviewed the mapping you provided, and it appears to be configured correctly in line with the steps described in the Academy course. Based on the information shared, we were not able to identify any issue with the mapping or validation rules, and we did not find the previously reported error.
Could you please restart the training environment from the Academy Playground for this specific training instance? Once the environment has been restarted, please check whether the issue still occurs and then perform the Smart Import upload again.
If the error reappears after restarting the environment, please let us know so we can investigate further.
