Board Engine Not Starting
Options
search in the forum"
Unable to Login: 64 bit license Error
here you shoudl find the solution
what is the exact size of the Key (in KB). Did you have started the keymanager with Administrative rights (run as admin)
regards
Björn
size of the key 1,56kb
And keymanager use run as administrator.
Hello Wahyu Nugraha,
the name of the license you're using ("naim land_MN.key") looks like the typical name of a "temporary board license".
probably it has expired.
please refer to your local Board Support to solve the problem.
best regards,
federico
- 106 Academy
- 282 Resources
- 158 Blog
- 305 Partner Hub
- 91 Support
