Drill through more than 7500 rows.
Options
Pablo Luis Rodriguez Longhi
Customer
I have a trouble with drill through.
When the user make a big selection, specially under "Total", I received an error message like "The query returned too many rows." this happened when the query result is more than 7500 rows. In this case the most value is 27000 rows for one month.
I use this kind of query to run a lot of detail information not handle by normal board behavior.
Someone knows how to solve this?
Professional IT Business Process Analyst
IVAX ARGENTINA S.A.
Argentina
IVAX ARGENTINA S.A.
Argentina
Accepted Answer
Hello
The limit on the maximum number of records supported on the drill through invocation can be customized. There is a parameter in the AdulaParams.xml (B10) or BoardEngineParams.xml (B12) file in the installation folder of the BOARD Engine. The parameter is the following: <DrillThroughCutOff>100000</DrillThroughCutOff>. By default is set to 10000. Changing this parameter requires the restart of the BOARD Engine during a maintenance window.
Björn
Björn Reuber
Support Team Manager
Board Deutschland GmbH
Germany
-------------------------------------------0
I changed the parameter and now it works fine!!
Thanks Björn !!
IVAX ARGENTINA S.A.
Argentina
