Idea :
Add an options to have a CRC* / Check Sum included in the Snapshot of a database to facilitate comparaison of entities, trees and cubes.
And when transporter package is run (or created) report the differences.
Would facilitate Pre-production go lives dry run, verification that "static" entities are properly filled, etc...
Workaround :
Extract all Cubes, all dimensions and trees, do a batch in windows to compare.
* like in 7zip :
