1. What is your idea?
I'd like to create a drill through that returns * fields of a table/view by referencing one or many Board objects in the web client.Β Right now I have to individually specify each field that is returned by a drill-through instead of a simple SELECT * query.
2. What specific problem are you trying to find a solution to, or what new scenario would this idea respond to?
- Reduce time spent creating and maintaining drill throughs
- limit impact on drill through if table or view structure is changed
- align on functionality available in the windows client
- Allow more flexibility with more complicated SQL queries used in drill-throughs.
3. What workaround have you found and used so far (if any)?
- Use the Windows client
- Specify each field individually instead of a SELECT * statement
Β 4. What is your role in your organization?
I'm a consultant in the organization.
