Upon the final check of data, everything lines up well, except for the GBP Sales Actuals Data screen.
I have walked through the module and rebuilt the entire procedure and data view several times, however am getting the same results.
The GBP report doesn't appear the same as the LC report in the numerical presentation. The dollars are not matching what the academy is showing for the GBP screen, however the LC screen does.
When the screen is filtered based on the required selectors per the lesson.
This is what my GBP screen is reporting:
This is what my LC screen is reporting (this matches the academy's GBP screen):
In the build of the ACT β Sales Data Publish; in step 4, there is a request for a ACT - DR - Units; however the build only has Temp - ACT - DR - Units or ACT - DF - Units. Is this a Typo, what should be used? Could this be causing my out of balance?
I would be greatlful if someone could please assist.
