Level 200-Module 204 : Material and Material Group, can't Match child-parent
As you can see in the screenshot_1 below, when I tried to match each material to its material group I got only binary values (column "Related Item Nr), it is supposed to be 4 columns : code, material, code and material group (see screenshot_2),
Also I can set only one Gold row to "1" , when I tried to set the other Gold rows, the one already set turn to 0.
Have I missed a step ?
Any assistance you can provide would be greatly appreciated !
Screenshot_1 : what I got
screenshot_2 : what I am supposed to get
Thanks!
Accepted Answer
Hello Nour El Houda
Thanks for posting to the Board Community.
What you see is the relationship viewer / editor from a parent to child perspecitve.
Since that relation is 1:N, the numbers indicate the amount of children.Therefore I suggest checking whether you have set the relationship correctly and rearrange/switch it.
Remember: Child entities have fewer dots next to them than their parent entity.
(e.g., ° Material, °°Material Group)
Good luck and please let me know if it worked.Best regards,
Filip
Filip Rankovic
Associate Consultant
Board Deutschland GmbH1
Hello Filip,
Thank you for your answer, it works now !
Acutally entities were not organised correctly (Child entities had more dots next to them than their parent entity).
Thank you for your help!
Regards!1
