Hello community,
Board application is refusing the use of special characters that we need to correctly write in French (e.g. é, à, è) or even currency symbols (I tested € and £).
Any time I write a special character inside a label, new cube name, block format, security role, etc, Board will clear the field. This is a big problem as we can't rename or create labels, buttons, cubes, procedures or anything else with an appropriated name when those characters are needed.
It seems it happened after a version update to v12.6 revision 0.2.91269. Board support has been contacted around the 12th of December but no solution has been provided yet.
Is anybody experiencing the same behavior ?
Thank you for your help!
