Hi All,
i have a problem with a calculation between 2 cubes
First of all, i want update the cube B (5 dimension) using the value of Cube A (2 dimension \the other 3 dimension i used the filter in the procedure) without delete the other part of the cube B.
the Algorithm use the cube A and B explained before. The reason of "if(a=0,b,a)" is to update the cube B with the new value of the cube A (only in the combination of Cairo 1, resisdential, principal payment, dummy and months).
BUT this it is useless if the cube B is empty in the interested section and if i try to use this dataflow the result would be zero.
so my request is to understand if it is possible to modify my algorithm and try to include the "empty"cube case
Best regards,
Andrea
