Level 200 : Module 210 : Issue in copying selectors
Accepted Answer
Hi Sailesh,
Thank you for highlighting this issue. When you copy the selectors and paste them into the Expense Planning screen you will face this problem where the selectors do not show the data.
To fix this, upon clicking on each selector (like your screenshot) you will see that the entity chosen is correct and the same. Please change the specific entity to another entity and save it, then edit it again and choose the correct entity for it to repopulate on the current screen correctly.1
Thankyou
