Hello, I’m currently trying to create a screen for the Capsule Translation where users can enter their own translations and then update them via a procedure. The problem I’m having is that, although I can successfully transfer translations made there via data entry in a cube into the actual translation file (e.g. CapsuleTranslationDE.csv) using a procedure with an export step, AND I can then see these new translations correctly in the localisation overview in the administration after a refresh, they aren't applied in the board capsule when I change the language there. It’s only when I manually enter or edit another translation directly in the administration on the Localisation screen that the other changes are also applied to the Board Capsule. Do you happen to know what might be causing this? Why its only synchronizing, when I do the change/entry directly in the localization overview?
