Is there any way to Drag and Concatenate more than one SQL Field by Drag and Drop(Auto mode) in Data
Hello Team,
Happy New year,
now my question is,
i have 2 SQL fields FirstName and Lastname,
I have created Just one Entity called 'Name'
Now i want to concatenate SQL fields FirstName and LastName (FirstName + LastName = Name) and append it to my entity Name
lets say if i do not want to use manual option for this, so is there any way this can be done via Drag and Drop in Auto Mode itself in Data Reader.
Much Thanks,
Malav
  • Alexander Kappes
    Alexander Kappes Employee
    Fourth Anniversary 250 Likes 100 Comments 5 Answers
    edited March 2020
    Dear Malav Shelat,
    only thing you can do is inserting the first field with drag and drop. The second has to be inserted "manualy".
    You can write it manually into the sql field.
    A little way to easy up this is using another entity (just temporarily during the configuration), inserting the second sql column into this and using (CTRL+C & CTRL + V) function.
    Using this, please don´t forget to remove the additional entity when your reader configuration is finished.
    Hope it helps
    regards
    Alexander Kappes
  • Hi, Alexander Kappes True, I follow the same process but just wanted to confirm that i am not missing any functionality pre-designed for this requirement,
    Thank you!
