Please Provide Some solution to find minimum value for the above problem statement
Hi swathi mp,
please provide at least which dimensions you are talking about--are those in the 2 Dim Cube part of the 3 Dim Cube as well or are they completely different?
Kind Regards,
Helmut
Yes 2D cube has same dimensions of 3d example 3d has x, y, z dimension and
2d has y, z dimension which holds minimum of X
On Thu, 15 Aug 2019, 11:13 am heheimann, <do-not-reply.community@board.com>
see also https://community.board.com/message/6551-how-to-find-a-minimum-value-of-a-cube-through-procedures
