Would you please explain exactly what procedure configure action Data Read > Relationships > Normalize option "Do not fix missing relationships (not recommended)" does? There's a double negative in there ... is the recommendation to always check that box? That fixing relationships is not recommended and to therefore not do it, so check the box?
Thank you,
Pete
