I have a process in a Procedure that puts a 1 into a cube where the outlet has data. This procedure is running very slow and I am trying to make it faster. I was previously using an if statement to say if that data in the first cube for the required date range then 1 else 0. This was very slow. I have created a cube that contains only the data that needs the 1. Therefore the if statement is no longer required. When I use the algorythm a=1, I would expect to see a 1 next to all detail from the cube, but I don't. How can I achieve this without the If statement. See attached is the process with the if statement. Cube A contains only the required data and I want to put a 1 into cube B, thanks.
