Is there a solution for completely individual column headers?
Hey,
is there a solution yet to show only what I want in a column header? I do not want to show the "2018" because behind that is a reference year 2017. Is it possible not to show the 2018?
Thanks,
Hannes Keller
Hi Hannes. Are you referring to the defaulted header titles which appear as soon as you create and add a cube a dataview, with an entity aligned by column? If so, no - I don't think so.
In these instances I use a workaround, like a headerless dataview for the data and a 'false' header structure, usually a custom cube, on top to show customised headings; the custom cube allows me to more easily control the column widths of both objects.
Unless anyone else knows a way, I hope at least I've helped you to know that there is not a simple 'overtype' solution to your question.
Hey Paul,
thank you for your replay. I think you are right about the defaulted header, which my problem is. I have no entities aligned in column but have references on year (detailed by) and a specific year.
I am not sure what you mean with headerless dataview and "false" header structure as well as custom cube. But I have not tried such things a lot so I might just dont know it yet.
Using References, it is not possible to replace the member title with a custom one. So long as I know how many columns I have 5, 10, [n] and that the number is fixed, I can create a custom entity/cube structure to sit above my dataview. So, if I had 10 fixed columns, I would do this:
- Create an entity [Fake Title]
- Add the following members as follows
1 - [blank]
2 - [blank]
3 - [blank]
10 - [blank]
- Enter no of cilumns in MAX ITEM NR
- Create a cube [Fake Title cube]
- Add the entity [Fake title]
- Create an Admin Screen
- Create a dataview
- Add Cube [Fake Title cube]
- Add the only entity [Fake Title] to the column axis
- Select dataentry [x]
- You should now have a dataview with a single blank but yellow row.
- Type the custom titles into the yellow numbered columns - if no numbers, switch entity from default to code.
- Save the entries.
- Copy the dataview
- Return to your working screen and screen Hide the header
- Reduce the far left column to minimum = invisible on web
- Now set column width to that of target dataview and position on top - you may also need to set it to the back so as not to interfere with operation of source dataview.
hide the headers of the fake title dataview.
I think that's the correct sequence - was this any good to you? Again, it is only useful for non-dynamic dataviews where the number of columns remains fixed and the data in them matches the fake title you have set.
4 -
Thank you again Paul for your ideas. I have not tried yet to use an individual entity to produce standard headers. But will keep that in mind for further, maybe more standardized, layouts.
