Context :
You have a block with data entry and it has both following features enable :
- pattern allocation
- Deep lockling
If the user apply the pattern base allocation on the cell, it won't take into account the cell that are locked for that perimeter and erased the value.
Idea :
Have the option make them work together natively. (maybe with a pop up asking the use or a check bock in the layout.
Workaround :*Not always possible* : recalculate the driver cube for pattern base allocation to account
